ExtLibA.SockLib.FndIPv4AddrOnIfFail
Description
Failed to find an IPv4 address on an interface. All-multicast mode will not be enabled on the interface.
Remedy
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Severity
Error
Message Text
Did not find IPv4 address on i/f %p1%. Cannot enable all-multicast mode.
Message Parameters
Name Type
p1 uInt32
